I took these pictures showing the process to a friend over Whatsapp, tougth I'd share it.
The bugger is hard to get to!
Got it out, but its still hanging on.
Lil' bastard.
So, time for the radiator, let me just remove the cover... Damned screw is stuck...
F%^k! I torqued a hole into the radiator. Spun it right out.
Well It was junk anyway, time for a new one!
After a hunt going between 4 diffrent bike shops and one bike breaker I got myself a new radiator and thermostat. Assembelly was WAY easier.
Hmm... Easy pouring...
So time to test it my new radiator and thermostat.
On the positive side: Radiator and thermostat work so well I couldn't get the oil temprature higher than 81 degrees C
On the negative side: I forgot to check if the fan thermostatic switch and fan work as intended, and I couldn't get it hot enough, even with Amsterdam's rush hour traffic.
My solution?
Succes!
Hope you enjoy some Schädefreude, for this is a prime example of Murphy's law.
And remember!
