The drive train has given me the most grief, the YANMAR aircooled engines (and clones) are very popular for many conversions due to their simplistic/functional design and power to weight/size ratio, but just as everyone else I would really like more hp. The YANMAR L100AE is comparable to a 150cc gas banger in power, from what I have seen and read about, which makes sense as its the same 9 hp for both.
At this point I'm favoring the three wheeler idea, it would also make the hydrostatic drive more possible due to the arrangement of required system components. I have a small enclosed all aluminum utility trailer I build many years ago and with little effort could easily convert to the drivers cabin to sort of a boxy BMW Isetta style.
I believe with proper component selection I should easily be able to attain 80% and over in system efficiency which I believe is higher then the CVT. I've put together a matching variable piston pump and vane wheel motor. I think I should be able to get about 80 km/h in top speed as the aluminum should keep the weight down and although boxy in design it will be an aerodynamic slopping front and low height.
I've even been thinking that at some point I could possibly add another YANMAR hydrostatic drive to increase the overall hp, a simple conversion of the wheel motor and the added flow will increase torque and top speed (flow = speed). While driving around town I could run a single engine and that at its sweet spot, then when required on highway stints simply fire up the second engine for extra speed. Sounds good too me in theory even considering the cost factor, as two of the L100 AE's are less then one 18 hp 3 cylinder water cooled YANMAR. Talk about back up ..... LOL
Any thoughts anyone? I know this is a Dieselbike forum, but technically a three wheeler has traditionally always been a modified motorcycle.
