Here I sit with half a broken tooth in my head, nursing it with scotch. So I'll probably be slering me words.
This is the situation.
reg rec when not at charge mode kicks out 2 amp to the battery (saves over charging it).
The aux / lighting circuit from the reg rec kicks out 7amps.
To stop the 7amps combining with the 2amps getting to the battery and over charging it when the lights are off, I have a rather unattractive flick switch on the bike. It ain’t right!
So I need a diode at the battery + lead that runs to the ignition switch, and the 7 amp aux lighting circuit joined between them.
But, what diode?
I know it can't be a zenor diode as that dumps to earth? Proberbly got that wrong
