I have a digital thermostat that controls the fans based on the temperature I set. The themometer sensor is stuck inside the cylinder head air passage with epoxy.
When driving the engine quickly warms up to about 75degrees C. If the bike is in continual motion, it hovers between 75 and 85 at this time of year in the UK.
When idling it slowly creeps up to 105 degrees, when my fans kick in. 2 fans are on the intake side where the flywheel would have originally blown air through:
The other fan blows on the side of the cylinder, this fan has since been replaced with a smaller one from a yzf-r125:
With the fans running, they draw 4 amps. They cool pretty quickly at idle and click off again at 98.
Removing the fins hasnt seemed to give the engine more acceleration capability, but it does rev a bit easier at the upper rpms, as its not being limited by the fans as well.
The only time it gets hot quickly in my experience, is filtering, or high rpm on low gears up hill. As there is little air flow and lots of fuel/acceleration going on.
So far, no evidence of overheating, hopefully it also increases the fuel economy slightly.
