Pulled the Trigger
Pulled the Trigger
I stripped down the donor and ready for power plant. If someone in the forum is using a 10 hp motor, care to share the performance with the motor: speed, accel and overall performance and what model turbo did you use. I would like to start with that size motor (budget). Thank you.
"Salty Olde Chief"
Re: Pulled the Trigger
Do some search in here. Pretty sure every configuration of 10hp bikes rarely got close to 55mph and mostly cruised about 45mph. Most recent experiment putting turbo on one had produced no upward change in performance. It's a good read search it out. It will be one of the most recent topics on turbos.
Thank you! I suspect that highway speeding is hard to achieve with 10 hp.
