ebay microcar cvt.
ebay microcar cvt.
http://www.ebay.co.uk/itm/AIXAM-MEGA-MI ... 337fb531d1
http://www.ebay.co.uk/itm/MICROCAR-AIXA ... 337fb59026
The driven pulley will be on a taper so ask for the tapered adapter to make your life easy when mounting. You could ask for the belt as well just for setting up purposes(around 250mm distance I think) Belts are expensive!!
The rear pulley should be 19mm so a suitable shaft can be made or bought.
This is the petrol version so the weights on the driven one may have to be changed to diesel weights. These are available at Aixam dealers and only cost a few pounds.
It is quite bulky so would suit the larger bikes or if mounted sideways possibly shaft drive.
Good price though!! :D
Re: ebay microcar cvt.
The primary clutch appears to be a Series 06 CVTech unit.
http://www.cvtech-ibc.com/client/page1. ... =4&clef2=2
The secondary maybe a LP3? The ebay ad does say it is for a Diesel Model.
http://www.cvtech-ibc.com/client/page1. ... =5&clef2=2
The diesel Axiam has a 2cyl Kubota Diesel
The driven secondary is described as petrol but the compatibility list says diesel?? Either way I would try it first and see how it responds.
