Thanks for the links. I'm certainly no engineer (unfortunately), I just like playing...
Unfortunately the clinton engine is the wrong way version.
I bought a mini bike before hoping to use the bits for mine, I stripped it down yesterday but it doesn't help as much as I hoped it would. The engine rotation is Anti Clockwise but a reduction gearbox reverses the drive - perfect! I stripped down the gearbox yesterday and I can't alter the reduction ratio of 5:1. This means I would need a 60T front sprocket which wouldn't fit... bugger.
The engines are these:
http://www.petrolscooter.co.uk/spare-pa ... gines.html
Next option, reversing the engine. A few ways to do this....
1) Reposition the flywheel or crankshaft keyway so in reverse the magneto would be correctly timed, or reposition the ignition coil to do the same. I don't know how easy it would be to make a new key way..... I assume just slow and fiddly. That would work, but in reverse the fins wouldn't aid in cooling the engine. I don't know how vital that is?
I would also need to get the starter to turn it the other way - hopefully easy enough.
2) Leave the engine running as is, but (somehow) move the starter to where the clutch currently is, and (somehow) take the driver off the starter end of the crankshaft. The engine would be running in the direction it was intended, I'm just not sure the crank would hold up to having the drive taken from the wrong side?
Other than that, it's swapping the wheel round, or using a jackshaft. In that case, I would rather then use a 4 stroke petrol engine - or a diesel!
No mixing of fuel and more reliable. The guy who sells the 168f also sells:
http://www.ebay.co.uk/itm/5-5Hp-LT160Q1 ... 41700e1987
http://www.ebay.co.uk/itm/2-5Hp-LT154Q1 ... 416c655a74
http://www.ebay.co.uk/itm/2-5Hp-LIFAN-1 ... 417011bdbb
