Fuel pump timing
Fuel pump timing
Hi all
I have been reading the service manual of my yanclone, but cm confused on how I need to set the injection timing.
so. What is the best way to set it.
At the moment, mine has knock at low rpm and is quiet at high rpm, I assume this is the correct timing?
I know that knock is good, it means that the ignition timing is occuring at the correct time, can anbody help me along a bit?
Re: Fuel pump timing
Post by BertTrack »
At lower rpm's it's normal to have some knock indeed. Aslong as it goes away when you climb in rpm's you're good.
