The engine information applies to the original Japanese Yanmar L100, and it's other Chinese diesel engine copies, such as Changfa, Punsun, Winsun 186F/CF versions.
In the middle of last April, suddenly my Suntom 186F engine decided not to start, and with very little compression after working fine the previous day, so a long and at times tedious process of finally fixing the diesel engine was started two weeks ago! Well, other more important priority things got in the way first!...
The thing to remember about these small diesel engines, is that they give very little warning that they are about to fail, which can be a problem!
The first thing I thought was to check the fuel supply to the injector, and check if it wasn't blocked and check the area for leaks. That was to cause me a lot of headaches in the future!
As I used the electric start, I didn't know that the engine compression was going.
This job can be done with the fuel tank in place; carefully undo the coupling nut with a 17mm spanner and pull out the high pressure metal fuel pipe. Then remove the two 10mm securing nuts and the injector retaining plate. Also disconnect the rubber fuel return pipe from the side of the injector, and stuff a suitable sized bolt in the end of the rubber pipe, otherwise fuel will slowly and relentlessly leak everywhere over the engine.
Then very carefully pull out the injector, it might need a little bit of careful levering out if it is very tightly located.
The copper shims quite often stick to the injector when removed, and you must be careful not to lose any of them! As they affect the injector operation. My one had three very thin shims installed. I stuck them together and in place, with a small smear of Vaseline, which makes life easier when refitting the injector.
After checking the condition of the injector tip and seeing if the four offset 'microscopic'
The pipe coupling is tightened to hand tight, plus around a quarter of a turn 'nipping up' with the spanner - that should prevent leaking. Then reconnect the rubber fuel return pipe from the side of the injector, after removing the bolt.
In the glass Jar you should have four fine spray patterns, and no leaks at the pipe coupling end! This is a high pressure system, so you have to be a little bit careful about high pressure fuel, and take precautions.
In my case, that looked ok, so it was time to really start taking things apart! The fuel tank has to come off now, plus the exhaust manifold and air filter.
Now I have to take off the rocker cover and cylinder head, as I noticed a small oil leak from the front of the cylinder.
Be careful when you take off the rocker cover and the four cylinder head bolts, since the rocker arms aren't fixed in one place,(they are normally held in place when the rocker cover is fitted) and can slide off the rocker shaft. My exhaust valve rocker always wanted to slide off for some reason, when not restrained!!
Time to take off the cylinder head, which is heavier than you think! well, it's a diesel engine!!! Make sure that tappets stay in place and don't get mixed up! I placed some paper towel to keep them in place, and stop unwanted items to fall into the tappet housing, which is quite wide.
Now we can see the mess on the cylinder head face and inlet and exhaust valves, created by my last unsuccessful bio-ethanol.vegetable oil mix - you have been warned now!!!
With the engine cylinder, you can easily see where the copper head gasket has blown, and the carbon crud deposits on the piston crown. The barrel honing pattern and condition looks good, just very oily! The combustion/swirl recess in the piston can also be seen, also clogged up.
So lots of time now spent carefully scraping and cleaning off the very hard carbon crust, on both the cylinder head and piston, which was a very dirty and boring job - that crud sticks to the surfaces like the proverbial s**t to a blanket!!!!
It's then time to inspect the valves and valve seats. Luckily I still have a very old car valve spring compressor lying around. Just brush off the dust and cobwebs, and it's ideal for the job!
Have to be careful that the valves, springs, spring retaining collets and seals don't get lost or mixed up! I found each valve and valve seat in good condition, but needed careful crud removal to get a good seal.
The cylinder head castings look quite well manufactured, it's just some the machining details on the mating faces in places, that lets the overall quality of the engine down. I suppose it's down to Chinese practice of meeting manufacturing quantity targets, rather than quality control targets. I found some small imperfections in the area where the cylinder head gasket had blown, so I used some fine emery paper and blended down the rough area as much as I could. I also went over the whole cylinder head mating surface and piston crown, with the fine emery paper to give a smooth finish again.
Time to refit the valves in the same way as they had come apart, with hopefully nothing left over!
