I found this "Haige Power 22 HP V-Twin Air Cooled Diesel Engine" on ebay, http://www.ebay.com/itm/22-HP-Air-Coole ... 032wt_1396.
Does anyone know anything about the manufacturer?
Haige Power?
DrunkInTheGarage
- I'm pretty new here..
- henneberg
Re: Haige Power?
No doubt it originates from China. From the type number 2M05P internet search didnt give any clear answer..
- DieselFly
Re: Haige Power?
Same engine is under a grand from Punsun. Shipping bites though. If you could get four people that all want an engine the shipping cost does not go up that much. You will really save if you can pick them up on the west coast.
Finished and riding 1975
CB500t Turbo Punsun powered
hardtail.
hardtail.
Re: Haige Power?
Interesting new Haige development
http://haigepower.en.made-in-china.com/ ... rbox-.html
Haige wrote: Model NO.: EV80
Fuel: Diesel Engine
Rated Output: 12kw/3000rpm;14kw/3600rpm
Cylinder: V-Twin, Air Cooled
Stroke: 4 Stroke
Speed: 900-3600rpm
Start: Electric Start
Fuel Consumption: 285g/Kw.H
Cooling System: Radiator
Usage: Suit for Small Vehical, ATV, UTV & Golf-Car
Certification: EPA, CE, ISO
Compression Ratio: 23:1
Export Markets: Global
Additional Info.
Trademark: HAIGE
Packing: Wooden Case
Standard: ISO, CE,
Origin: Fujian, China
HS Code: 8502120000
Production Capacity: 3000PCS/Month
Product Description: 800cc v-twin motorcycle engines diesel 20HP(Complete set with CVT transmission & Gearbox)
Engine Features:
1) Compact structure, light weight and energy & material saving
2) Adopt the CAE analysis, reliable
3) Low-emission design technique, with the less pollution and emission
4) Apply the tunnel structure to enforce the strength of cylinder block, low vibration and noise
