To resurrect an old thread...
There is an article "Last Oiling" in the 9/1994 issue of Oldtimermarkt by the German motor journalist legend (or so
http://classic.dieselkrad.info/dieselmo ... dhatz.html say; for the complete article in German with an advertisement picture of the Albertus engine, go to "mehr Bilder" right under the bike picture) Ernst "Klacks" Leverkus; a Zündapp to Hatz conversion is discussed there. More intriguingly, tho', is the following:
"Diesel motorcycles? Germany had'em, too. Four firms tried from 1922 to 1925, and now, there are two of'em on the road again - this time with starter cranks.
First, briefly of diesel bikes in Germany and Great Britain (which I shall omit since it is the Norton diesel bikes already on this site): Albertus-Motoren-Werk Richard Schulz in Königsberg, and Albertus Fahrzeugwerke AG in Achern 1922-1924; Almora Motor & Fahrzeug AG in Kassel 1924-1925; Bafag (Badische Albert-Fahrzeugwerke AG) in Achern 1922-1924; Deloma Kraftfahrzeugwerke in Magdeburg 1924. These four firms were all connected in some form, most importantly, they all used exclusively Albertus crude oil engines with
157 ccm (9.58 cu in) and 1,5 PS (roughly 1,55 hp) at 2500 RPM
or
212 ccm (12.94 cu in) and 3 PS (roughly 3,03 hp) at 2200 RPM,
constructed by the engineer Julius Loewy from Königsberg and patented at Deutsches Patentamt under the number 391786. These were three-channel (transfer, inlet, exhaust) two strokers, using decompressor for starting and gasoline and spark plug for warming up glow plates in the combustion chamber before switching over to diesel. Fuel was carbureted via a needle regulated nozzle in the transfer channel so there was no fuel inside the crankcase; nor was there a throttle. In the combustion chamber of the unitary cylinder/cylinder head piece (Sackzylinder in German motorist lingo), the carbureted diesel oil ignited by the combined effect of 9:1 compression and glow plates. To keep the cast iron cylinder cool, an aluminium jacket with massive cooling fins was situated over the cylinder's upper part.
The engines' power was quite on par with light motorcycle engines of the time - smaller engine having enough torque to diesel bike and rider up the mountain at Solitude Mountain Race (at Schloss Solitude in Hessen) along the 7 kilometers of the road in 9.18 minutes - amounting to average velocity of 46.65 kph.
Toni Bauhofer's Megola, for comparison, made it there in 4:29,4 minutes, averaging 93 kmp - but that was with the Megola's 750 ccm divided among five cylinders!"
To sum it up: Not bad at all, and even if not true diesels but carbureted hot bulbs (injection implementation missing): With combined ignition of glowing body and a relatively high compression, reasonable MPG should be achievable even without injection since no stochiometric ratio need to be kept.
Especially, if the compression part is upped to 10:1 or 11:1, and fuel is pre-heated at either the cylinder head or the exhaust manifold - or both, ensuring a more complete burn.
Pre-heating would also make for finer dispersion and lower the ignition delay of the diesel fuel and thus net higher possible RPM, but might necessitate slight throttling to retard ignition at lower RPM. Most importantly, without an injection pump to take care of, one could run waste motor oil or waste veg oil with but crude filtering - if the base engine is cheap and easy enough to rebuild.
Oil for lubrication would still have to be carbureted in at crankcase inlet or administered by some droplet oilers - if one were to keep it crankcase-scavenging two-stroke, of course. Four stroke would be harder to implement due to valves in the head which would constantly overheat; limited space in the head for a glow body would make things even harder. Compressor-scavenged (supercharged?) two stroke?..
Your thoughts?
EDIT:
@Zarquon
Maybe none survived? Three years of production makes for what, one thousand at the very most, considering that times' very many makes of light motorcycles in Germany. I'm with you on the emissions, of course - one would have to "fake" an Albertus bike of similar-looking parts, and fake markings on those parts as well to have the bike pass as antique and thus bypass emission tests here in Germany.
However, I shall try and make such an engine out of whatever junk I find in the garage just for shits and giggles - as soon as I'm done dieselizing me scooter, that is - and hereby encourage anyone with spare time and parts at hands to do it, too...
