This is the official build thread for my 2008 Kawasaki KLR diesel powered dualsport motorcycle. My wife bought this bike for me in December 2007, as a Christmas present. It has been through a couple of different variations from a touring bike with Pelican hardbags to a stripped and lightened trailbike. My diesel project bike has been stripped of the original gasoline engine and all of it's stock parts. Many of the stock components will not be reused. As the design evolves I will post updates.
The first picture that I will post is the motorcycle that was the original inspiration for my bike. When I first saw this motorcycle I knew I had to replicate it for myself. As I have always wanted a diesel powered motorcycle. I will post both pictures that I have to show each side of the bike. This bike has a 10hp diesel engine and a Series 40 & 40D CVT. The owner reports that it is capable of 65mph topspeeds. I have no way of knowing what is even possible until I finish and test my version.
My diesel project bike has been stripped of the original gasoline engine and all of it's stock parts. The Diesel KLR456, which I will call it from now on, will use a 2007 KLR swingarm and rear brake parts. I may have to convert the motorcycle to a right-side chain final drive. The wheel will be turned around and this appears to be fairly easy. I may need a few custom parts but nothing really expensive. When finished, it will look a great deal like the motorcycle pictured above but will differ at the rear. It will have a 2008 rear subframe, side panels and rear fender. It will use inverted forks from a 2008 KX450F. The inverted forks will be much ligher than a stock KLR, so the difference in weight for the diesel project bike should be considerable. An add-on dualsport wiring harness from ProCycle will also be used. The next pictures are of what I have to date. The frame needs to be lengthened in the front section in order for the diesel engine to fit. New downtubes will be fabbed from 1" DOM tubing.
Thanks for looking! Enjoy the pictures! Post any thoughts!
SamM
