Hi
Check out EBay Diesel Generator Nice engine for someone, good looking engine under the covers however the crankshaft rotation is the opposite direction to normal i.e. clockwise.
http://www.ebay.co.uk/itm/Honda-E4000-V ... 1c23638fcf
Cheers Tim
EbayUK Honda 500cc V twin Feb 2nd 2012
realnutter
Re: EbayUK Honda 600cc V twin Feb 2nd 2012
yay!
That's the engine I'm using!!! It's 500cc...well 479... and yes it turns backwards!
Hi
Thanks for the correction, I have one lurking in my garage and considering using it .How did you do the transmission and clutch on yours? I am curious about how it performs I have a Yanmar 400cc clone that will push along at 52mph 55mph top but is not very happy!!
Cheers Tim
Cheers Tim
realnutter
Re: EbayUK Honda 500cc V twin Feb 2nd 2012
Hi Tim....
I'm still in the process of building, but will be running it with the flywheel on the right, belt drive (1:2) ratio to a dummy crank in a Rotax 350 bottom end... and then the clutch and gearbox is as Rotax intended!
I have a build thread here, more details will be added when the weather improves and I can get on with it.....
