To my understanding (limited though) it is the high compression ratio primarily causing this nature. My search for low compression diesels revealed some SAE papers but no build attempt on the same lines.
http://subscriptions.sae.org/content/920545/
http://papers.sae.org/830588In the present work, investigations were carried out on a single cylinder, low compression ratio, spark-assisted low heat rejection D.I diesel engine. An extended electrode spark plug was used. Performance and emission tests on the engine were carried out with diesel fuel at two compression ratios, 10.5 and 12.5. In each case the engine was tested as a normal engine as well as a low heat rejection engine. The test results show that the low compression ratio spark assisted diesel engine operates very smoothly due to the low peak pressure and low rate of pressure rise. The low heat rejection spark assisted diesel engine gave an improved performance and reduced emissions compared to the normal baseline diesel engine. The low heat rejection, spark assisted diesel engine at 12.5 compression ratio gave the best performance among the tested configurations, with an improved thermal efficiency of 3% and a reduced exhaust smoke level of 1.5 Bosch units when compared with normal baseline diesel engine with 16.5 compression ratio.
http://books.google.com/books/about/Spa ... icNwAACAAJA single-cylinder, open-chamber direct-injection (OCDI) diesel engine was converted to low compression ratio, spark-assisted operation. A modular construction cylinder head was built for the test work. The research work indicated that on a typical OCDI diesel engine, several spark plug locations are possible to produce successful ignition of a wide range of fuels. Performance tests were run with different compression and swirl ratio combinations. The best combination was found to be 12.2 compression ratio and 10 swirl ratio. The spark-assisted engine (CR 16:1) was performance tested with methanol and DF-2 plus 20% methanol emulsified fuel. The spark was always required with methanol, however, with emulsified fuel spark was desirable for starting and warming up periods.The investigation suggested the feasibility of economically developing multi-fuel spark-assisted diesel engines.
These make me want to be convinced of the feasibility of LCR-SI-DI diesel but not so about its suitability for motorcycles. In theory if atomizing (by injection), vaporizing (by glowplug till engine is warm) & ignition with timing (by spark) are taken care of then diesel should burn good.Conventional diesel engines suffer from problems of excessive weight and size and excessively high rates of pressure rise and peak pressure because of the requirement of very high-compression ratios for the purpose of ignition. They also lack multi fuel capability. The use of electrical or other precise ignition means obviates the dependence on high compression for ignition and would allow the diesel engine to operate at the more efficient and practical compression ratio of 12 to 1. To accomplish this, an innovative ignition system with an unusually high rate of energy delivery was used in conjunction with a modified diesel engine. This new design was found to provide approximately equal efficiency under most operating conditions other than high load, and to provide instant cold start at the more desirable compression ratio of between 11 to 12 to 1. However, problems of spark plug fouling by the fuel spray made this approach impractical for this specific application. Approaches for handling the problem of plug fouling have been suggested in this report.
What all technical & performance issues might need to be taken care of for motorcycle usage
Excuse my poor English, its a second language for me. Cheers..
