You can see the manual from their website for info about wiring etc. at http://www.phitesla.com/downloads/RadonUsersManual.pdf
Phitesla radon speed/tach
- royaldragon
I just ordered the radon display stupidly without really reading up on it.
I swore I saw something that said the tach used mag pickups but turns out that's not true. It works with, and this is from the manual(don't have the devise yet), a TCI/CDI ignition or CB points ignition. Now I have no idea what this means.
What I am wondering is, is it possible to rig something up with this so I can get an rpm read? Or am I stuck without that feature? It would be a bummer as that and the temperature sensor are the only reason I am purchasing such an item. It's a little tacky looking but if both those features will work than it is worth it to me.
dragonmotors.net
dragonmotors.net
Mouse
Re: Phitesla radon speed/tach
I've just had a scan over the manual in the link and It would be very easy to simulate a points / contact breaker TCI / CDI signal using a magnet on a rotating part and a magnetic sensor. The easiest that comes to mind is to get a pulsar coil from some random scrap engine and use that and a magnet on the flywheel / output shaft (however I'd be inclined to attach a pair of clamping zener diodes to be on the safe side) I wont go drawing up anything just now as I've just got in from the Big Knock and am very tired
PS: I'm in the trade of making one off and custom electronics if you need something made up for you
- royaldragon
I wonder if I could use the magnet setup from a bicycle speedometer as well. Either way sounds like I can figure it out with some friends here. Thanks for info Mouse.
I would hire you out for the job but money is tight especially since I keep spending it on stuff for the bike
It's all worth it when I'm finished though right?
I can't wait to get on her and ride!
dragonmotors.net
dragonmotors.net
TedV
I built this circuit for my VW Scirocco 1.6TD autocross car. http://www.4crawler.com/Diesel/CheapTri ... ndex.shtml The circuit simulates the signal from the gas engine coil. VW diesels with tach received a signal from the alternator.
I used the optical sensor but someplace I saw where you can substitute a Ford hall effect sensor on a trigger ring.
transducer to clamp to fuel line at http://www.tinytach.com/tinytach/diesel.php
and for even more money dakota digital has some on a page http://www.dakotadigital.com/index.cfm/ ... cat287.htm but if money is tight, forget dakota digital
- royaldragon
TedV, that's pretty sweet! A little more complicated than I need I think. If I can manage a magnet that would be less work and I don't want to spend $100 either. I was thinking more like $50 max and if it could be more like $20 even better I even have a bike computer I could sacrifice if i knew it could work.
dragonmotors.net
dragonmotors.net
Nice one Ted. Next time I disassemble my motor I will contemplate painting the flywheel
