battery choice
battery choice
Ok what batteries do you recommend to start a single cylinder engine? Bearing in mind the smaller size required to fit in a motorcycle frame?
Re: battery choice
I would recommend VARTA and not to go for gel batteries they are full power one day and nothing the next, What you need to know is the CCA which stands for cold cranking amps, only a few batteries give this information and VARTA are one.
Re: battery choice
When I changed my single cylinder Enfield to electric start I used exactly the same battery as is used for the petrol electric start bikes so as to allow me to use the standard part battery carriers etc. I'd agree with Sam - I used a Varta Motorcycle YB14-A2 which came with an acid pack to make it up and has proved pretty indestructable despite my best efforts including draining it totally flat. Varta also do numerous shapes and sizes plus terminal configurations so you can't go wrong with them.
- balboa_71
Re: battery choice
This may not help you at all, but for those in the US, I'd go with an Odyssey. I've got one of their PC625 batteries, and it starts my Yanclone engine rather well. It's military grade and can take a lot of abuse dealt by my engines crappy undersize alternator.
