( viewtopic.php?f=36&t=1292#p8475 )
( viewtopic.php?f=36&t=1292#p8476 )
I have recently resurrected the project as it has had to be put aside for various reasons,the main one being lack of room in my workshop due to other projects/useful spares(or junk as my wife calls it) No imagination these women
I considered going the Enfield route but cost was a consideration and as I had the major parts to hand I decided to start again,
I have mounted the engine and added a down tube to support the engine but I found clearance a problem. I intend to fit a 16" rim on the front.This avoids cutting the frame so should pass the UK M.O.T. test.
The Robin engine is a bit of a lump and has to be offset to the right to line up.
The Aixam transmission is still an unknown quantity but because of the tight fit I may have to reverse the direction of the sliding tips to allow me to move it backwards a little.
I believe it is actually a comex? unit made in Canada for snowmobiles?
In the pic the rear pulley is the wrong way round but I may have to put it back the same as the pic. This will allow a couple of inches rearward movement to adjust the belt tension.The belt isn't actually in tension but I have found out that the pulley centres are app. 250mm apart. It works in the same way as the Comet units but the belt is much larger so wear on a bike should be better.
I have been collecting some MZ bits so once the engine/transmission is lined up to my satisfaction I hope the cycle parts will rapidly come together . Having done a few bike rebuilds in the past you probably know that it is always the smaller parts that take time eg brackets,exhaust etc.
Initially it will be an economy build as a "proof of concept" but once the problems are ironed out I'll strip it down again and rebuild with a bit more quality.
Hopefully it might be up and running this year.
Just to add I have mounted the rear pulley shaft on 2 pillow block bearings individually and have used turnbuckles(see pic) to adjust the shaft/pulley to get alignment. The shaft is mounted direct to the rear MZ engine mounts which pivot on the swinging arm and use rubber bushes as standard so these should allow a bit of movement! Once I have got it all lined up and running I'll fix the mountings so that they are more rigid in relation to each other but still have the rubber cushion(if that makes sense?)The forks are now on and I'm working on the rear end re mudguard etc.
I'll take some pics shortly and if admin wants to move this topic please do so.
