Hi all,
anyone know of the technical name for the 5 speed Enfield gearbox mainshft splines?
If anyone has the technical drawings so much the better.
Ian
5 speed box, Tech name of mainshft splines?
Anorak_ian
Re: 5 speed box, Tech name of mainshft splines?
Say what? http://www.jainenfield.com/gears.html
Anorak_ian
Thanks for the reply, but I needed a technical diagram of the splines, noting every angle, and mesurments of grooves and splines.
There should be a propper tech name for this spline arangment, Bsi, Din, Ansi etc.
Sorry should have said, it's the splines where the clutch fits over.
I knew I had this somewhere
This is all I have of the box itself.
Anorak_ian
Thanks for that, I'm sure that they will be very useful.
I was going to get an engineering company to make a bolt together coupling to extend the 5 speed gearbox shaft, using the tech drawing for guidance.
This would have saved me butchering a couple of Enfield clutch centres. But I have decided to just get on and make it.
Thats odd the post has come up twice. Bizarre.
[FIXED- moderator]
[FIXED- moderator]
