Here I was rattling my brains looking at everything down to fuel, valve clearances etc, also thinking back to what I had changed or added to.
Then it hit me! No way - it couldn't be adding oil to the gearbox grease surely? So I have dumped the greasy oily mess out of the box to find it had churned itself into a thick goo
I let it drain overnight as it came out in blobs, and then topped it up with a good quality motor oil and test rode the bike.
Either it's just me, or it's true fact! Thick oil = GOO takes some of the H.P away from the engine resulting in poor pulling power up hills, into wind etc. It's still no race machine, but from the speedo it has helped.
Now as far as I know - filling the gearbox with motor oil is OK, but like always I have to say it's up to the owners accountability if you wish to try it.
Best of all, I cannot see any oil leakage - "YET"
My explanation is, the grease tends to fling off the gears/components, with most of it settling away from moving parts - then when oil is added, it dilutes down to a thick goo that churns up around the components robbing H.P from the engine etc.
Thought I'd post this one up for those experiencing the same type of problems.
Andrew
