Last time I did I was looking for a set of taper rollers to fit instead as the loose ball bearings are a real pain to do with the casquette as you WILL knock some off when fitting (at least for the first half dozen attempts), sadly none were available at the time.
As mine need changing (again) I had a quick scour through the Hitchcocks toys catalogue and guess what's now available.....don't ask the price though (if you have to ask then you can't afford them...)
Anyhow, I can see why the cost is high as one of the bearings has been step bored for an adapter for the top fitting as well as some outer bearing adapters so it will cost a bit to make.
So here we go:
I won't cover removing the old ones as this is kind of obvious and straightforwards, try not to be lazy like me and do it without disassembling the handlebars and cassette as you will then have to do it later when the whole lot is suspended from a strap around the garage roof supports....
One thing I should have done the first time around - fit a grease nipple to the headstock pipe, I don't have any in stock but I have drilled and tapped the thread ready to fit one so hopefully this is the last time I will have to change the bearings (especially at this price...)
We shall just block it off with a little button head for now.
Here's the top cup fitted with it's adapter:
The same goes for the bottom one.
The adapters look like this:
Then the outer taper cup fits inside it (very tight fit)
Here's the underside of the cassette with the adapter installed:
Bad photo but you can just make out the bored out step in the inner race to fit over the stem:
BTW instruction leaflet from Hitchcocks score 2/10 and as my school report used to say 'Must try harder'...
