Trike conversion
A room dedicated to those building Diesel Powered Trikes
dieselbikin
Trike conversion
Post by dieselbikin »
Now that I'm partially paralyzed,I need more stability, so I'm converting my bike into a trike. My design is simple and relatively cheap. My only concern is the durability of the 1" axle peerless 100 differential. It is rated for the weight and hp, but probably not the speed or tire diameter I would like to use.
[img][IMG]http://i488.photobucket.com/albums/rr24 ... gnwqm.jpeg[/img][/img]
[img][IMG]http://i488.photobucket.com/albums/rr24 ... wtu33.jpeg[/img][/img]
1980 Suzuki 550
10 HP Yanclone
94C Comet
dieselbikin
Re: Trike conversion
Still have to mount outer bearings.
Image[/img]
Image[/img]
[URL=http://s488.photobucket.com/user/d ... jpeg[/img][/url]
1980 Suzuki 550
10 HP Yanclone
94C Comet
Post by mark_in_manchester »
You don't hang about, do you!
I would have thought that the diff would only be doing very much when the wheels are rotating at different speeds - in a straight line, it's all locked up and so long as the bearings can handle the torque without collapsing - which seems very unlikely - you'd be OK. So the way to kill it would be to have *really* long half-shafts / wide wheelbase and go as fast as you can on full-lock. Or use two rear wheels of different sizes. Or try to do trick-riding with one rear wheel off the ground :-) As you're not going to do this, then it should stand up OK, I would have thought.
(That last one - one driving wheel off the ground - comes to mind as something my friend with a Ukrainian Dnepr MT16 with sidecar wheel drive, tells me one really mustn't do - it kills the diff, since the planet wheels start wizzing round like billy-oh rather than just correcting minor speed differences between the two outputs).
dieselbikin
Well I'm street legal again. Went riding yesterday. Only quirk is that it pulls somewhat to the left because the axle is 3 inches off center. May put a wheel spacer on short side. I was going to use the sprocket as my brake disk but I don't have enough room. Trying to use a Honda Civic disk from another project.
1980 Suzuki 550
10 HP Yanclone
94C Comet
Great work Chris. How about some pics. Or better yet, a video clip!!
Well done. You're a stubborn man. Good for you. Course make sure that stubbornness though does not put others in a bad spot.
Side note to to mull over..... Esp. for someone with limited mobility. They say Reverse. trikes are way more stable and safe than a Rear Trike.
dieselbikin
Trying to put a rear brake together. Was adapting a Honda Civic brake , but going back to original Suzuki rear. Since I didn't make a integral chain adjuster, I'll be making a chain tensioner. Now that I have a "smart" phone I can log my data with gps.
[img][IMG]http://i488.photobucket.com/albums/rr24 ... w5xip.jpeg[/img][/img]
I will get some video soon. My disability is primarily in my left leg, so I should be ok. Thanks for all the input.
1980 Suzuki 550
10 HP Yanclone
94C Comet
dieselbikin
Wrapping up the rear brake. As soon as my new, longer diff bolts show up I can button it back up.
[img][IMG]http://i488.photobucket.com/albums/rr24 ... lodd1.jpeg[/img][/img]
1980 Suzuki 550
10 HP Yanclone
94C Comet
dieselbikin
1980 Suzuki 550
10 HP Yanclone
94C Comet
dieselbikin
1980 Suzuki 550
10 HP Yanclone
94C Comet
dieselbikin
Finally got to ride today. Rear brake line somehow got severed ang chain link almost broke, so I'm waiting on parts again. My gps app malfunctioned or I averaged 79 mph. Lol.
1980 Suzuki 550
10 HP Yanclone
94C Comet
Tetronator
Post by Tetronator »
dieselbikin wrote:...My gps app malfunctioned or I averaged 79 mph. Lol.
Noice. 8) Teach me your tricks.
Honda VT600 C Shadow
H̶o̶n̶d̶a̶ ̶C̶B̶R̶6̶0̶0̶F̶2̶
Mercedes-Benz W123 300D Sedan
dieselbikin
The peerless has already failed, but I think my bearing support was inadequate. I've built a much stronger structure for the next one.
[img][IMG]http://i488.photobucket.com/albums/rr24 ... st8u5.jpeg[/img][/img]
1980 Suzuki 550
10 HP Yanclone
94C Comet
dieselbikin
I've been searching for a compact differential solution for quite awhile. So far the best I've found are from garden tractors. I'm hoping to win a diff with axle on eBay. Cub Cadet has been the best vale so far. The set up I'm trying to buy is a two piece diff with 30mm axles. This is the preferred setup for pulling competitions. They put up to 60hp through them!
[img][IMG]http://i488.photobucket.com/albums/rr24 ... 949gax.gif[/img][/img]
1980 Suzuki 550
10 HP Yanclone
94C Comet
UAofE
Post by UAofE »
You need some kind of damper/bushing between the sprocket and axle/diff.
dieselbikin
I've finally got my cub diff and axles. The axles are shorter than I'd like, but I'll make the best of it. Just waiting on parts as usual. [URL=http://s488.photobucket.com/user/d ... jpeg[/img][/url]
1980 Suzuki 550
10 HP Yanclone
94C Comet
dieselbikin
My cub cadet axles ate too short so I'm making new ones. I'm also rebuilding the rear framework to accommodate dual rear disks via kart rotors and Suzuki katana calipers. Hopefully I'll hav pics in a week or so. Forever waiting on parts.
1980 Suzuki 550
10 HP Yanclone
94C Comet
dieselbikin
[/url]
Rough draft of rear end:
Comet industries 8" brake disks
Suzuki GSX600 brake calipers
Hybrid axles OEM grafted to 1" kart axle with coupler
And kart hubs.
As soon as my axle and coupler show up I can finish.
1980 Suzuki 550
10 HP Yanclone
94C Comet
dieselbikin
1980 Suzuki 550
10 HP Yanclone
94C Comet
dieselbikin
Still getting rear brakes worked out, but ready for tomorrow's test run.
1980 Suzuki 550
10 HP Yanclone
94C Comet
Looking great Chris. I love that wide stance.
dieselbikin
Here's a grainy video of my bike and my latest result. Top speed has dropped off with my shorter tires. My max rpm reached is 3200 and my CVT is fully shifting according to my sharpie line on the driver. I've lost 5 mph and not sure how to get it back.
[URL=http://i488.photobucket.com/albums ... .mp4[/img][/url]
[URL=http://s488.photobucket.com/user/d ... .png[/img][/url]
1980 Suzuki 550
10 HP Yanclone
94C Comet
dieselbikin
Finally got to make some test runs. Since bike weighs more and is less aerodynamic I figured I would try some tuning.
Original 4.6
5/1
4.2
The 4.6 had highest top speed, but 4.2 had highest average which seems more important. I will play with the driver tomorrow.
1980 Suzuki 550
10 HP Yanclone
94C Comet
dieselbikin
My best trike run so far. My goal is 50 mph top speed. Correct me if I'm wrong, but the fastest run would be one in which the final drive and shifting of the CVT was such that the engine stayed at its 3600 rpm horsepower peak? My RPMs never get past 3300, so I'm wondering if there's a little more left.
1980 Suzuki 550
10 HP Yanclone
94C Comet
UAofE
Post by UAofE »
CVT will never be ideal without electronic or manual actuation. You will have to compromise:
Holding maximum RPM for power/speed, but very high RPM for takeoff and low speed maneuvers.
Low takeoff RPM and good economy, but "shifts up" early and limits top speed by lugging the engine.
Mine for example will equalize belt speed with the engine (stop slipping) at 13mph and can hold 3400-3600rpm up to 40mph, where it "locks up" to it's top ratio and acceleration is very slow to 60mph.
If I lighten the pucks to raise the "locking" speed the engine is always at high RPM at low speeds.
If I lighten the pucks too much the engine speed stays at maximum with little acceleration (loading of the engine).
So far, I have machined 3 pucks lighter to give an in-between 2000rpm of the factory 1900 and 2100rpm engage speed options. 40-55mph is slow going, but if I can get to 55-60mph I can maintain it easily due to engine speed being in the power range.
What I would like to devise is a manual control for the drive pulley using the bike's clutch lever and cable. A clutch throwout lever with a sealed/greasable bearing would work. The drive clutch would then be weighted to a higher than normal mass to work as a "booster" but still allow the throwout to control the sheave.
A side benefit is that it would allow the CVT to operate the engine as a brake in deceleration instead of fully opening to idle.
dieselbikin
Getting very close to my goal. Been lightening to pucks to slow the up shift. My RPMs are finally getting close to 3600. Next run will be with 5/1 ratio.
1980 Suzuki 550
10 HP Yanclone
94C Comet
dieselbikin
UAofE,
What was you finally decide on for your final drive ratio and puck weights? Thanks.
1980 Suzuki 550
10 HP Yanclone
94C Comet
Eddy Wane
Post by Eddy Wane »
Just wondering what the screen shots are - app or whatever.
dieselbikin
It's an iPhone app called Speed Tracker.
1980 Suzuki 550
10 HP Yanclone
94C Comet
Eddy Wane
Post by Eddy Wane »
Thanks for that. Just found the android version called Speed Tracker Free. It looks very similar, if not the same, to the Apple one.
