The c.v.t. unit is now operating in a nice rpm.
Overall engine rpm. has dropped nicely and i can do 100km/hr at 3000rpm or less.
Adding 2 grams to the weights has made the bike crawl a tiny tiny tiny bit. (Pushing it forwards and backwards with idle engine i notice no difference though) So i suspect it's only when it's just started. And runs at 940 rpm.
An even bigger influence on the smoothness of the engine and drive line was balancing the 6 weight combo's in the primairy cvt. Whereas I had a 2.5 gram difference before between certain weight packages i evened them out to within 1 hundredths of a gram. This alone (separate step) cancelled out the heavy vibration at lower rpm.
Fuel usage has dropped to 3.3 liters on 100km. Enough for me considering the 2l in 100km figure was gotten with a fixed gearbox only.
Remaining item of getting enough charge seems to be an issue mainly in the winter time. So I will address that coming winter.
There are items that have to be changed or checked still based on the info from the producer. He'll provide the parts and info. So I will have to wait on that to get started on that. (I will do that work myself
I suspect to be riding more than fixing things from this point on. So if someone still has questions or would like to know something specific, ask me.
Should any big things rise up though I will keep you informed.
