(UK) LOMBARDINI (Ruggerini) PARTS FOR SALE
Hi, I have a load of Lombardini parts for sale, so if you need something let me know.
Piston ring sets, loads of different sizes.
Piston kits, pins, clips, rings.
Gasket packs.
Workshop Manuals.
Valves.
Oil pumps.
Big end shells.
Filters air, oil, sump.
I will be cataloging and listing it all on my website in time (when I get time that is).
Ian
Gasket packs.
Workshop Manuals.
Valves.
Oil pumps.
Big end shells.
Ian
Re: (UK) LOMBARDINI (Ruggerini) PARTS FOR SALE
if they are parts from more than one model engine you may want to mention this even before you catalog it. If it's only one model... it would be good to know.
I would think "Piston ring sets, loads of different sizes" would give people a clue.
I will of course be stating the part number, size, and what engine it is intended for, along with a photograph of the item.
Not meaning to be snooty.... consider not assuming as much. For example ... "different ring sets" could just as easily be standard ring sets as well as sets for same engine in various common over bored cylinder/sleeve sizes.Anorak_ian wrote:I would think "Piston ring sets, loads of different sizes" would give people a clue.....
It'll be lonely this Christmas,
without you to bone.
It'll be bone, bone, bone, without you at home,
this Christmas.
Sorry, I always sing when I'm drinking.
this Christmas.
hi ian, do you have an air filter to fit the ruggerini md150/151 or the lombardini 25ld425 (same thing,as you probably know).i just need the attachment to the air supply, not the whole thing. or anybody else reading this have one lying around?
cheers, jonny.
cheers, jonny.
Hi mate, would that be like a big rubber ring / seal at the bottom of the filter?
I certainly have a lot of filters, but I haven't had time to do anything with them yet.
Do you have a model number of the filter? or ring?
Ian
Ian
thanks but no, not the filter, i mean the whole steel canister that mounts up to the aluminium air inlet. i actually only need the first part of the attachment, so as i can connect a modern auto air filter up to it....i¨ll look for a part number.
Oh I see, you need the air in take pipe that bolts to the manifold?
I have one for a Rug rd210, I'm not sure, but I think that I didn't use it as the internal diameter was smaller than the manifolds hole. I didn't want to restrict the breathing, at least I think that was the reason.
I used a Harley exhaust manifold bracket and cut down the pipe, and the K&N is on the end of that.
Though I do worry about water getting in to the engine when I go through heavy rain. I may change mine for one of those enclosed filters you see on eBay.
I'll take a gander, and see what I have.
thanks ian, if you still have the rd210 fitting could you let know what diameter the pipe is and what size the bolt holes are please?
Hi, sorry I haven't looked for that part yet,
I've been busy battling may car insurance company to cough up some cash for my damaged Audi A6, Insurance co now say no, and now I'm up to my neck in engine parts.
Also been busy trying to buy a pub and campsite, ooer loads a fun there.
I'll get in the the garage today and take a gander and get back to you tonight.
Hi, I just took a look in the Lombardini boxes, and no filter housings / manifolds,
and the rd210 filter housing must have been sold as it isn't here anymore. Darn.
Sorry I can't help you.
thanks anyway ian, good luck buying the campsite/pub!?
- henneberg
Hi Ian,
Do you have piston kit for the MD150/MD151 engine - 80 mm diameter,
regards, Erik
regards, Erik
Hi Erik,
No sorry,
The only piston kits that I have are three kits for a 9LD 561 (95mm bore), may also fit the three cylinder 11LD.
I have just found a website that helps me identify the parts that I have, part numbers to Engine models, so now I can start cataloging what I have.
No sorry,
Redkite
G'day Ian, As with Erik, I also have an MD150, with low compression on one pot, Not had time to strip it yet, and hoping to find a valve not seating,
but I'm guessing that I may need piston/rings/barrel, or oversize piston/rings.
I will look out for your list, as there will be other bits needed.
Have to say Ian, I envy your collection of pre-1960 machines - Free tax, No MOT, - Moto-Nirvana !
Bob.
Bob.
Hi Bob, there all in boxes, patiently waiting for parts and logbooks. Too many jobs and not enough time.Redkite wrote:I envy your collection of pre-1960 machines.
I'm selling one of my project bikes as there's no way I'll ever get her finished, I got too ambitious.
It's on my website, http://www.dieselbiker.webspace.virginmedia.com/ my diselbiker.co.uk site is down again.
I'll try to get some more work done to the parts list to night.
Ian
Blimey what a dopey git I am! I forgot to post the webpage http://www.dieselbikebuilder.webspace.v ... _parts.htm
I still haven't finished the list, I still have a tray of filters to do.
