It is -24c outside here in northern Finland, so a good day to be on the internet!
I've started a diesel bike build this winter and I'm making slow and steady progress, and thought I'd share some pictures for your entertainment, and also have some questions.
The bike is originally a K-750, made by KMZ which later became to be known as Dnepr. I've restored to original condition two similar bikes, so the technology is familiar to me, hence the selection. As an engine I've got a Winsun 22hp purchased directly from the factory in 2008. Below some pictures of my progress. I'm using the original 4speed tranny, still not sure if I'll use the 9% faster or 30% faster 4th gear and what final drive ratio, I've got all the parts.
Two questions (for now
1) -I've read some worrying threads on cranks braking on the Punsun 22hp engines. Has anyone made any final conclusions on that? Eg certain years were worse etc. I'm also hopeful the problem is not with Winsun, as to my best knowledge Punsun and Winsun are made by a different company. I'm not sure but it seems both factories are in Nantong but have different addresses, contact persons and telephone numbers. Could be the parts come from the same place though.
2)-has anyone tried to change the injection lines on these engines so that instead of the line coming up from the pump to sideways? It would require an L adapter and either some bending of the original tube or new tubes. The pipes currently interefere with the top frame tube when removing the engine requiring the removal of the subframe.
Anyway, some details of the build below. Overall it has been fun to build but surely is taking a LOT more time then I anticipated.
-Frame bottom tubes are widened, bent forward and the whole frame is lengthened about 7cm.
To strengthen the bottom tubes and drop the engine in the frame (for looks and gas tank clearance) I welded some 40*4mm bars on the tubes and have made them into box. This picture is missing the final piece welded completing the rectangular structre
The engine is bolted to a subframe with rubber bushings
here is a picture of an earlier stage of engine fitting. In it you can see how the injection lines will intefere with the fuel tank and are the critical dimension in removing the engine (eg for crank replacement
I have more pictures and I can also update moving foward if there is interest.
Happy dieseling!
sno-bro
